Engine case ID
Engine case ID
Postby coaster » Sun Oct 02, 2016 8:54 pm
Hi, fresh back from Wicksteed where I picked up a 200 casing for a decent price. It is stamped SX200 but the numbers look a bit uneven. The part number inside is 19610054 which is not the SX number I don't think, anyone have any ideas, GP maybe or Indian?
Colin
Re: Engine case ID
Postby missing lynx » Sun Oct 02, 2016 10:42 pm
or stolen
Re: Engine case ID
Postby Dimitrios_231 » Sun Oct 02, 2016 11:10 pm
TV200,not bad :)
Dimitrios_231
Re: Engine case ID
Postby xenia1 » Sun Oct 02, 2016 11:43 pm
missing lynx wrote:or stolen
Not necessarily , many cases have uneven stamps..
xenia1
Re: Engine case ID
Postby coaster » Sun Oct 02, 2016 11:50 pm
Thanks again Demitrios.
I'll have a closer look at it but the number does look as if it has been hand stamped but it has some damage which has been welded up and might have led to it being scrapped at some time in the past and then repaired and re-used?
Re: Engine case ID
Postby Dimitrios_231 » Mon Oct 03, 2016 12:14 am
It is an early TV200 crankcase without the bottom hole for the exhaust bolt.
Another one
Dimitrios_231
Re: Engine case ID
Postby coaster » Mon Oct 03, 2016 7:46 am
Thanks again, mine has definitely been changed at some point, the star and Innocenti motifs have gone although the area doesn't look as if it's been ground and has the same patina as the rest of the case. There is a large area of weld on the underside of the gearbox which I think would have been good enough reason for it to have been scraped back in the day as beyond economic repair.
Re: Engine case ID
Postby nickw » Mon Oct 03, 2016 9:16 pm
Our group saw that. Good price I thought but the numbers were definitely re stamped. Didn't look at the inside of the casing but saw welding on outside and assumed gearbox had gone through. I'm presuming it was the casing on Fatbloke's stall. His prices are always fair. Dimitrios is correct in saying it is a TV200 casing although don't know what other casings the number may have been used in.
nickw
Re: Engine case ID
Postby Dimitrios_231 » Mon Oct 03, 2016 9:27 pm
Same pic,zoom in ;)
Dimitrios_231
Re: Engine case ID
Postby Dimitrios_231 » Mon Oct 03, 2016 9:40 pm
Later TV200 models had the same number with SX200 19610160
Dimitrios_231
Re: Engine case ID
Postby Dimitrios_231 » Mon Oct 03, 2016 10:06 pm
nickw wrote:... although don't know what other casings the number may have been used in.
Probably none,the closer that I can find is early TV175 S3 with 19010054
zoom in :)
Another one
zoom in
Dimitrios_231
Re: Engine case ID
Postby coaster » Mon Oct 03, 2016 11:10 pm
Re: Engine case ID
Postby coaster » Mon Oct 03, 2016 11:20 pm
nickw wrote:Our group saw that. Good price I thought but the numbers were definitely re stamped. Didn't look at the inside of the casing but saw welding on outside and assumed gearbox had gone through. I'm presuming it was the casing on Fatbloke's stall. His prices are always fair. Dimitrios is correct in saying it is a TV200 casing although don't know what other casings the number may have been used in.
I don't know who Fatbloke is but this was a very large stall manned by 2 guys one of which was quite large who I recognised and the other was normal build and it was him that was selling it as well as some other bits including an RB kit. The price came down a bit from adverised with a bit of haggling ;)
Re: Engine case ID
Postby nickw » Wed Oct 05, 2016 7:59 pm
Yep, as pm'd I got mixed up where I had seen it lol.
Dimitrios, I don't know how you manage it but you always seem to have the right answers with pictures to prove. Invaluable.
nickw
Re: Engine case ID
Postby Dimitrios_231 » Wed Oct 05, 2016 8:24 pm
Τhey call it magic,
just kidding ;)
Dimitrios_231
