Annoying metal clips on rear runners
Postby davla » Fri Sep 09, 2016 8:51 am
Is there an easy way to fit those annoying metal clips onto the rear runners? I never seem to be able to get them pushed on far enough, especially on runners that have been removed and re-fitted.
davla
Re: Annoying metal clips on rear runners
Postby Adam_Winstone » Fri Sep 09, 2016 9:22 am
Cut an inch wide strip (about 4 inches long) out of a plastic milk carton/bottle and use it as guide/slide to fit the clip over the top. Slide the clip + strip onto the frame leg, then pull the strip out.
Adam
Postby Digger » Fri Sep 09, 2016 9:46 am
Adam_Winstone wrote:Cut an inch wide strip (about 4 inches long) out of a plastic milk carton/bottle and use it as guide/slide to fit the clip over the top. Slide the clip + strip onto the frame leg, then pull the strip out.
Adam
I'm not getting that Adam.... :?
(Could be an age thing) ;)
Digger
Postby HxPaul » Fri Sep 09, 2016 9:59 am
davla wrote:Is there an easy way to fit those annoying metal clips onto the rear runners? I never seem to be able to get them pushed on far enough, especially on runners that have been removed and re-fitted.
If you mean the side panel buffers that fit on the frame leg,then Adams way of fitting them will work very well without scratching the paintwork.http://lambrettarestorations.blogspot.c ... ffers.html
Postby Marty ULC » Fri Sep 09, 2016 10:38 am
I think he means the clips that fix the plastic strips to the runners. I'm sure someone once suggested using small nuts that would self-thread on the plastic spikes.
Marty ULC
Postby Digger » Fri Sep 09, 2016 10:45 am
Marty ULC wrote:I think he means the clips that fix the plastic strips to the runners. I'm sure someone once suggested using small nuts that would self-thread on the plastic spikes.
That's what I thought he meant - hence my confusion with Adam's tip which now makes sense after Paul's post. :)
Digger
Postby HxPaul » Fri Sep 09, 2016 11:56 am
I usually push those small speed clips that fit the rear runners into position and use a pair of pliers to push them completely home.
Postby Storkfoot » Fri Sep 09, 2016 1:00 pm
A small socket say 8mm
Postby foremanbob » Fri Sep 09, 2016 3:18 pm
Storkfoot wrote:A small socket say 8mm
+1
foremanbob
Postby gizmo » Fri Sep 09, 2016 4:02 pm
+1
And me, spent years struggling and tried this by chance. Soooh easy
gizmo
Postby davla » Fri Sep 09, 2016 6:11 pm
davla
Postby Digger » Fri Sep 09, 2016 7:59 pm
Digger
Postby Adam_Winstone » Fri Sep 09, 2016 8:37 pm
LOL.... Yes, my mistake.
Postby davla » Fri Sep 09, 2016 9:33 pm
Adam_Winstone wrote:LOL.... Yes, my mistake.
Haha! I least I've learnt something new. Regarding the other tips, I tried the socket option and had no luck. I've got a small pair of pliers though so I'll give that a go. Thanks for the replies.
davla
Postby bazza3004 » Fri Sep 09, 2016 11:40 pm
I think ive prob broke more than ive fitted. I usually push down with a pair of pliars eitherside of the plastic pin but ive had loads that snap one side of the sprung clip off. Think il try the small socket idea next time.
bazza3004
Postby Tractorman » Sat Sep 10, 2016 8:48 am
We used these 'speed nuts' to hold the rear footboards on when entering events, standard classes that required full bodywork. Then all you had to do if you needed the footboard off quickly was a quick yank upwards and the clip fractured, saved messing around with sockets.
Postby Digger » Sat Sep 10, 2016 9:20 am
Tractorman wrote:We used these 'speed nuts' to hold the rear footboards on when entering events, standard classes that required full bodywork. Then all you had to do if you needed the footboard off quickly was a quick yank upwards and the clip fractured, saved messing around with sockets.
Although it hasn't been confirmed we believe it's the little rectangular clips that fix the plastic runners to the footboard that is the topic.... ;)
Digger
Postby HxPaul » Sat Sep 10, 2016 9:38 am
Postby Dimitrios_231 » Sat Sep 10, 2016 3:01 pm
Nice trick,thanks for sharing ;)
A hammer,a socket extension and a 6mm socket for 1/4 inch rachet,are the needed tools for the job.
A 5mm socket might be better (6mm is my smaller socket)
Dimitrios_231
Postby Tractorman » Sat Sep 10, 2016 5:30 pm
Yes that's what we used, you can push them down the threads on the rear foot board clips instead of turning them down the threads hence speed nuts.
