Italian or Indian
Italian or Indian
Postby kennystag » Wed Aug 10, 2016 10:56 am
Hi All,
How can you identify weather a Lambretta engine, 125, 150, ect is a Italian or Indian.
Stag
kennystag
Re: Italian or Indian
Postby burnside » Wed Aug 10, 2016 12:20 pm
What's the engine number, shouldn't that reveal it's origin?
burnside
Postby Paulnobodyimportant » Wed Aug 10, 2016 12:43 pm
Can't find a relevant photo on google, but if you look at the engine mounts on the flywheel side, the Italian ones and I think Spanish ones have a central stiffeners, as shown below, but note that the photo below is for the kick start side. For the Indian engine, they have 3 stiffeners in the middle portion, but only on the flywheel side.
On the kickstart side they have the central one, as the Italian casing.
Paulnobodyimportant
Postby kennystag » Wed Aug 10, 2016 12:49 pm
What I think is that the early Indian engine casings had the innocent logo on them. What I am trying to find out is how can I tell where the engines where built .
kennystag
Postby kennystag » Wed Aug 10, 2016 12:53 pm
Hi Paul,
I did not not see your post until I sent my response to burnside.
Stag
kennystag
Postby burnside » Wed Aug 10, 2016 1:22 pm
kennystag wrote:What I think is that the early Indian engine casings had the innocent logo on them. What I am trying to find out is how can I tell where the engines where built .
But don't the Indian casings have a S prefix, or is that just the later ones?
burnside
Postby kennystag » Wed Aug 10, 2016 1:30 pm
Thanks for the information Paul, but I am not sure what you are saying lol.
Stag
kennystag
Postby Paulnobodyimportant » Wed Aug 10, 2016 1:47 pm
I have an Indian engine with no numbers and an innocenti logo stamped on it. So to help you I will post a picture of this engine tonight, once I get home, unless someone beats me to it.
Paulnobodyimportant
Postby kennystag » Wed Aug 10, 2016 1:49 pm
Thanks Paul.
Stag
kennystag
Postby Paulnobodyimportant » Wed Aug 10, 2016 8:09 pm
Hi Kenny, difficult to see on the photo below. But if you look at the lug under the engine mount on the flywheel side, you will see 3 stiffeners (red lines) on this Indian engine. However, on the kickstart side, there is only one stiffner, as shown on my original photo to both Indian and Italian engines. Seemingly, the Indians put in the extra stiffners due to the requirement for a stronger lug to cope with their bad roads.
Hope it makes sense, as just finished a BQ in this damp rain.
Paulnobodyimportant
Postby Adam_Winstone » Wed Aug 10, 2016 9:06 pm
^... like. Show us the other side, as Paul says, and we'll know for sure.
It looks like a new SIL casing to me.
Adam
Postby kennystag » Thu Aug 11, 2016 12:57 pm
Paul,
Many thanks for taking the time to explain the difference.
Kenny
kennystag
Postby rossclark » Thu Aug 11, 2016 11:35 pm
A lot of Indian casings still have the Innocenti casting.
Indian casings have extra ribs on the flywheel side as has been stated above. The sometimes also have inspection holes in the brake backplate. You'll also often have a number painted on the outside of the casing which should also be on the endplate of it is a new casing. The casting will often be quite rough and show signs of crazing from the mould.
If the engine has a number then SIL ones will often have the S prefix and number will look like a blind beggar with St Vitus Dance stamped it...
Postby Steve J » Fri Aug 12, 2016 9:18 am
Not strictly true - early Indian engines look pretty much the same as the Italian ones on the flywheel side, with only one stiffener on the engine mount lug. Another clue is that the Indian castings have a rougher surface finish. Maybe due to using Innocenti's old tooling well past its sell-by date?
Paulnobodyimportant wrote:Hi Kenny, difficult to see on the photo below. But if you look at the lug under the engine mount on the flywheel side, you will see 3 stiffeners (red lines) on this Indian engine. However, on the kickstart side, there is only one stiffner, as shown on my original photo to both Indian and Italian engines. Seemingly, the Indians put in the extra stiffners due to the requirement for a stronger lug to cope with their bad roads.
Steve J
