"Quiet" muffler required
Postby peejay » Sat Aug 02, 2014 1:28 pm
hi peeps
i'm probably asking for the impossible but here goes.
i'm currently running a Performance pipe with a "quiet" stainless muffler. when i say "quiet" i'm comparing it to my Sito Ancillotti with stainless downpipe that i had fitted previously.
no way is this new pipe what i call quiet (and i'm deaf in my right ear).
can anyone point me in the right direction for a muffler that gives a genuine reduction to the loud "crack" that i'm lumbered with at the mo.
here are details of the flange i have to fit to:
thanks for any help guys :)
Re: "Quiet" muffler required
Postby Scooter Paul » Sat Aug 02, 2014 2:25 pm
Can this one be repacked with good quality fibre mat from a MX shop?
Scooter Paul
Postby peejay » Sat Aug 02, 2014 6:33 pm
can this be repacked?
Postby mickyb » Sat Aug 02, 2014 9:00 pm
yes, but you've got to drill the rivets out first
mickyb
Postby rossclark » Sun Aug 03, 2014 12:10 am
Getting the band back on and it rivetted on is a PITA as well
Postby Digger » Sun Aug 03, 2014 6:28 am
rossclark wrote:Getting the band back on and it rivetted on is a PITA as well
Yes but it can be done - It gets easier the more you do. :)
Digger
Postby peejay » Sun Aug 03, 2014 9:17 am
thanks guys for the info :)
Postby Scooterlam » Sun Aug 03, 2014 12:54 pm
Has anyone had any success with the cap type arrangement used on early frescoes.
We fitted a similar device to kart pipes to beat noise restrictions at tracks.
Scooterlam
Postby jonno » Sun Aug 03, 2014 8:13 pm
I made this for my JL3,but the centre pipe wasn't the same size so had to make another.Centre pipe 28 mm approx 23mm from centre for fixing holes which are 40mm apart.You could drill and helicoil new holes if needed..O/A size 76mm.Its staimless with 10 mm ali ends,so is heavy and you'll need another bracket,but it knocked 6db off the pipe noise. £35 plus p&p if your interested
jonno
Postby Wack » Mon Aug 04, 2014 5:53 pm
I've always found carbon or alloy tube better as it seems to absorb the noise better than stainless. A new JL can seems to last about a fortnight until it makes your ears bleed.
Postby peejay » Tue Aug 05, 2014 9:18 am
hi Jonno
thanks for the offer of that end can, i would like to stick with the one i have if possible (if i can repack it) or a different one that would bolt straight on.
Postby Toddy » Tue Aug 05, 2014 12:15 pm
Peejay
Have a look at these as an alternative and easier to re - Pack
http://www.ebay.co.uk/itm/LAMBRETTA-VES ... 772wt_1190
Postby rossclark » Tue Aug 05, 2014 9:38 pm
Darrell Taylor was doing some at one point in Carbon that were supposed to be quiet.
Postby Toddy » Tue Aug 05, 2014 10:03 pm
rossclark wrote:Darrell Taylor was doing some at one point in Carbon that were supposed to be quiet.
I tried one , a bit quieter but didnt seem strong enough IMHO if you are doing a lot
Of miles
Postby peejay » Wed Aug 06, 2014 8:13 am
thanks Toddy for that, i like the circlip idea :D
