fitting an ignition switch to my S2
Postby Watfordwhite » Tue Aug 09, 2016 9:59 am
I want to fit an ignition switch to my late S2 instead of the cut out. I have a Beedspeed elec loom, 3 wire. Has anybody done this and any advise before I file the headset?
Watfordwhite
Re: fitting an ignition switch to my S2
Postby Donnie » Tue Aug 09, 2016 12:43 pm
Donnie
Postby gaz_powell » Tue Aug 09, 2016 3:48 pm
I did it on my indian s2 - hardly had to file anything out - just offer it up and take your time
I had to rework some of the wiring but it was nt difficult from memory.
Postby Tractorman » Tue Aug 09, 2016 8:48 pm
As Gaz says it should fit almost straight in, scootopia one tend to be a little bigger. You only need to wire up the green wire to use the switch for security.
Postby MK Monty » Tue Aug 09, 2016 10:57 pm
I found the switch itself to be thick steel and I filed /ground the switch rather than the housing, also some have a very thick rubber cover that all add to the bulk on the rear size, the hole at the front is the easy bit
MK Monty
Postby Watfordwhite » Wed Aug 10, 2016 7:04 pm
Thanks guys for the links and information. Very helpful. :D
Watfordwhite
Users browsing this forum: Google [Bot] and 66 guests
