swissdean wrote: RT195 on 107/58 mec crank, 3mm packer at base and squish bang on
corrado wrote:swissdean wrote: RT195 on 107/58 mec crank, 3mm packer at base and squish bang on
Why did it need a 3mm base packer with a 58 x 107 crank? That should only be necessary with a 58 x 110 crank.
Feersum Injun wrote:Mine only has 2.5mm packer with 60x110 crank..??
Toddy wrote:Feersum Injun wrote:Mine only has 2.5mm packer with 60x110 crank..??
It may have, alot depends on the deck height of the casing
