Re: Stuck rings
Post by ToBoldlyGo » Tue Jul 26, 2016 2:09 pm
I'm sure I've read it somewhere that fully synth is probably a bit excessive for everything except the more sporty engines. Basically it is too good, and because it coats so well doesn't get burnt off as it should. Could it leave residue that slowly gums your engine up, I wonder?
Re: Stuck rings
Post by Meds » Mon Jul 25, 2016 8:18 pm
Agree completly, these threads are really interesting.
I'm running EXoil fully synthetic in 2 motors (one iron, the other Nickasil) at 4%, I have done around 2000 miles between them and haven't had a problem. I changed due to the good reviews.It's smokey on start up but seems to clear quickly.
The reason I'm interested it this fault has a common cause and we are blaming an oil, I think we should be looking at other contributing factors, like
Over oiling and running hot.
Fuel/oil additive reactions
Oil/heat/material interactions, ie something in the rings or piston acting as a catalyst.
If there are any chemists amongst us can they please add to the reasoning.
Just a thought, the oil is gumming up and solidifying in the rings causing them to stick. Symptom.
Could the oil be collecting in the area cooking off the lighter parts and leaving some form of tar that solidifies and shrinks as it cools.
That might sound daft, but two of the posters have said, running fine stopped and lost compression,
If the rings were jammed in before they stopped it wouldn't have run, so the ring positions are likely to have changed state after they stopped, hence the shrinkage and jamming.
This is only a hypothesis, and as such can be challenged/supported
Post by davej » Thu Aug 04, 2016 11:16 am
Will add a couple more observations if I may-
One of my bikes is a completely standard SX200 after using Rock Oil I changed over to Exol, Back at the end of May rode from Southampton up to Shaftsbury however on the way back on encountering a long hill to climb I started losing power and had to change right down to second and ease the bike to the top. Back at home I stripped the bike and found a stuck Top Ring. This happened after riding approx. 4000 - 4500 miles using the Exol. Having re done the Top End have now done a 1000 miles still using Exol. The mixture I use is 50:1. Doubt in my mind do I carry on with Exol ?
Last weekend another one of club members travelling back from Exmouth on a Standard TV175 encountered the same problem on a rather long incline the bike give up completely. On stripping he found stuck rings and hole in Piston, He again had changed to Exol at the same time as myself and had done in the region of 4000 miles. Is this just a coincidence? or should we take these incidences as something more? Looking forward to more interesting comments!
ToBoldlyGo wrote: Exol and I'm going to use the bloody stuff if it kills me. .
johnnyXS wrote:.....Lambrettas and VEs*as have been using mineral oil for over 60 years without any issues that I am aware of .
coaster wrote:johnnyXS wrote:.....Lambrettas and VEs*as have been using mineral oil for over 60 years without any issues that I am aware of .
You are forgetting that we had to do regular de-cokes back then which would include removing the rings and cleaning the groove with an old broken ringI suspect that the racers wouldn't experience problems for similar reasons i.e. regular top end strip downs.
HxPaul wrote:Just as a matter of interest,is semi-synthetic oil mixed with mineral oil and thats what makes it semi,but fully-synthetic isn't.
