dickie wrote:What's the theory behind nitride? I thought it was used to reduce static friction.
[/url]IMG_0172_zpsy4i54a3g by stephen holt, on Flickr[/url]
[/url]IMG_0171_zpsdxhwqypq by stephen holt, on Flickr[/url]
[/url]IMG_0170_zpsrrqf2gpm by stephen holt, on Flickr[/url]Warkton Tornado No.1 wrote:It's a great project. I'm sure it will work well but no doubt you are ahead of any problems with the drive train...
I wonder what gearbox you intend to use.
I believe that of all the original types that the GT/TV 200 is the strongest.
Personally, I've had the specially manufactured gears brake with use in only a Group Four motor without being subjected to real race abuse, so I dread to think how they would handle the likely torque you should predict.![]()
If I can suggest it, don't skimp on the clutch, particularly in ensuring that the clutch clears well, without any element of drag as that really adds more likelihood of breakage.
My apologies if you are ahead of me here, but it would be a shame to not be able to utilise the performance you should gain.
IMG_0178_zpsqfqitchr by stephen holt, on Flickr][/url]
IMG_0179_zpsimehkjsr by stephen holt, on Flickr][/url]
[/url]IMG_0177_zpsvktc46bl by stephen holt, on Flickr[/url]Wack wrote:It will cost but I think Casa are bringing out a big cush drive clutch to use with their special side casing which I think also fits standard casings. Also you will find that a Ser 2 shock is longer and will give less clearance at the top end to frame, either a Yamaha R1 or similar may help.
Post by Wack » Fri Dec 09, 2016 7:18 pm
IMG_0190_zpscjsyhsic by stephen holt, on Flickr][/url]
IMG_0245_zpsg6hobc4j by stephen holt, on Flickr][/url]
IMG_0617_zps1ucdloih by stephen holt, on Flickr][/url]
[/url]IMG_0618_zpsxsv20sjk by stephen holt, on Flickr[/url]
[/url]IMG_0619_zpsnvkjaedq by stephen holt, on Flickr[/url]holty wrote:
