by eyeguy » Mon Aug 01, 2016 4:31 pm
Would anyone have some good pics on running the wiring loom on an early series 3 Li. Sticky's isn't not very clear in my opinion.
Eyeguy
eyeguy
by rossclark » Mon Aug 01, 2016 9:11 pm
by eyeguy » Tue Aug 02, 2016 12:21 pm
Thank you. Don't know why I couldn't find that.
Where would you hook the earth wire for the tail light. I've heard different ways?
Eyeguy
eyeguy
by foremanbob » Tue Aug 02, 2016 12:32 pm
eyeguy wrote:Thank you. Don't know why I couldn't find that.
Eyeguy
Depends how confident you are on earthing the frame and earthing the rear light to the frame.... personally I run an earth wire from the rear light unit to the earth on the regulator....
foremanbob
by eyeguy » Tue Aug 02, 2016 2:17 pm
I think that's what the original would have been. I will run to the regulator.
Thanks again
eyeguy
by rossclark » Fri Aug 05, 2016 7:46 pm
Originally it's likely that the rear light unit earth went under one of the nuts that hold the unit on. This usually means scraping a bit of the paint off to secure a good earth.
by Dimitrios_231 » Fri Aug 05, 2016 9:00 pm
My rear light earth.
Dimitrios_231
by rossclark » Fri Aug 05, 2016 10:02 pm
And if you're going for concourse you can bet that's right ^
Users browsing this forum: Baidu [Spider], Google [Bot] and 79 guests
