12V AC Rev Counter Options?
Postby Adam_Winstone » Mon May 02, 2016 2:52 pm
Hi all,
Whilst I realise that many people have now moved on to SIP speedos, with the range of functions that they offer, I'm looking to replace a toolbox top mounted analogue rev counter and wonder what my options may be?
In the past I've tried using one of the more common types, which can work on 12v AC or DC but found that running it AC meant that it didn't remember the number of cylinders that it was set for the next time it was used. This resulted in having to reset it each and every time I turned the ignition off... a little frustrating to say the least! I understand that this does not happen if you run it on a DC system/setting but I do not want to run a battery and would rather have no tacho!
So, what are my options for a 12V AC analogue tacho? I want to keep it analogue as the vintage nature of the bike means that digital is out of place. That said, if people have a recommendation for a cheap/good/round one (digital) then I'd consider fitting one to a different bike of mine.
Any help/suggestions welcomed.
Thanks,
Adam
Re: 12V AC Rev Counter Options?
Postby coaster » Mon May 02, 2016 3:15 pm
Ok so this is digital but it doesn't require any setting up, just one wire to thread down and wrap around the ht lead. It is powered off an internal battery and is on all the time recording RPM while the engine is running and changes to a reading of hours run when it doesn't sense an ht pulse. I've has one for about 4 years now on my Jet, never misses a beat and at £8.99 it's a bargain.
http://www.ebay.co.uk/itm/Digital-Hour- ... Sw8cNUM17M
Postby MickYork » Mon May 02, 2016 3:36 pm
coaster wrote:Ok so this is digital but it doesn't require any setting up, just one wire to thread down and wrap around the ht lead. It is powered off an internal battery and is on all the time recording RPM while the engine is running and changes to a reading of hours run when it doesn't sense an ht pulse. I've has one for about 4 years now on my Jet, never misses a beat and at £8.99 it's a bargain.
Same as mine and works fine........shop around though and you'll get one cheaper, I paid just over £5 :) http://www.ebay.co.uk/itm/400800493832
Postby AlG » Mon May 02, 2016 5:11 pm
Same as mine on my S-Type, works fine, but more for fun and amusement as it isn't always easy to read at speed.
AlG
Postby tim_mason » Mon May 02, 2016 7:12 pm
I run a Westach tacho on one of my scoots , Easy to set up .
tim_mason
Postby Adam_Winstone » Mon May 02, 2016 7:14 pm
Thanks for the responses so far.
Adam
Postby Adam_Winstone » Thu Jul 28, 2016 7:03 pm
Still looking and now need one more than ever as this baby can rev ;)
Please let me know if you've found one that actually works?
Adam
Postby Timexit17 » Fri Jul 29, 2016 1:29 pm
I was looking for a Krober Adam and found these instead -absolutely brilliant, very smooth indication and in a variety of colours too.
Motoplat and a Spanish one at that.
Only PITA is that you have to charge their own internal batteries and they don't last for more than a few hours.
Bought mine from a Spanish dealer off eBay for around £70 IIRC?
FWIW, I doubt it pulls much current so a mod charger should be able to power it permanently -I've mysteriously had 2 of those go however in the last 3 years so I'm building my own design to supply 12v & 5v with a more robust design.
Timexit17
Postby Warkton Tornado No.1 » Fri Jul 29, 2016 7:40 pm
It’s good to see Motoplat still using the Krober/Pitsch mouldings.
Do you have a link for the supplier, please?
Postby Timexit17 » Sat Jul 30, 2016 3:07 pm
Bought from eBay Spanish dealer but I can't recall who and it was some time ago so I can't see it in my purchase history either I'm afraid.
There's one here but I think that was more than I paid!
http://www.ebay.co.uk/itm/Contagiri-Mot ... 1720731333
Timexit17
