Oversize lever pivots?
Postby Leotech » Sat Jul 30, 2016 10:27 am
Who makes or sells the over size brake and clutch lever pivot bolts, not seen them about for a while?
My clutch lever / shroud is very worn and I'm losing clutch pull because of it.
Leotech
Re: Oversize lever pivots?
Postby rossclark » Sat Jul 30, 2016 10:29 am
Try MB or Torbay Lambretta who stocks their stuff
Postby HxPaul » Sat Jul 30, 2016 11:29 am
Most people with old scooters have to use oversized leaver pivots pins,especially on the clutch side.I got some from here and repaired mine.
http://www.ebay.co.uk/itm/LI-SX-GP-TV-S ... 46508837d2
Postby Leotech » Sat Jul 30, 2016 4:21 pm
HxPaul wrote:Most people with old scooters have to use oversized leaver pivots pins,especially on the clutch side.I got some from here and repaired mine.
They look pretty rough on the photo, doesn't say what diameter they are either?
I'll have a look at MB.
Leotech
Postby rossclark » Sat Jul 30, 2016 10:43 pm
Postby HxPaul » Sun Jul 31, 2016 8:26 am
P&P £4.50
By the way,the pins that I have are 8mm.
Postby rossclark » Sun Jul 31, 2016 11:36 am
I bought some small bits from Torbay a while back and they refunded the difference between what it actually cost and what the webshop said for the postage immediately.
Postby Leotech » Sun Jul 31, 2016 8:38 pm
I think ill have to get some made with oversize heads and maybe 10mm shanks, its a series one and the holes are getting on for 10mm on the longest edge of the oval!
I lose about 10mm of cable pull on the clutch.
Leotech
Users browsing this forum: Baidu [Spider], Google [Bot] and 64 guests
