Coughing N Spluttering
Postby plantphoto » Mon Jul 18, 2016 9:46 pm
Had a new 30mm Dellorto set up a couple months ago on my TS1 and all was good.
Since then the engine needed new rings and crank etc fitted. I've now run things in and started to give it some beans.
However after filling up last week (premium fuel at 3 percent mix of oil) I found the scooter started to hesitate like it was short of fuel when I accelerated hard (more noticeable in 3-4th gear)
This has got worse and is due back on the rolling road this week.
I just wondered if it could be blocked main jet or if anything else I could check before the slow ride to garage.
Simon
plantphoto
Re: Coughing N Spluttering
Postby hullygully » Thu Jul 21, 2016 6:30 pm
have you checked your plug aint starting to die?
have you checked your stator readings when stators warm?
Postby isthmus » Wed Jul 27, 2016 4:05 pm
to my eye i would first overhaul the carb and fuel system,also make your elecky system is tight,and clean,your earths on your stator could do with a check,specially if its indian[known to be loose]ybefore i started to go any deeper,hope this will help,simon
isthmus
Postby Adam_Winstone » Thu Jul 28, 2016 7:42 pm
I'd drain the carb and tank and try some different fuel.
Postby Raveydavey » Fri Jul 29, 2016 10:11 pm
Adam_Winstone wrote:I'd drain the carb and tank and try some different fuel.
+1
Raveydavey
Postby johnnyXS » Fri Jul 29, 2016 11:00 pm
and maybe consider fitting a fuel filter if you haven't one already. ;)
johnnyXS
Return to Carburettors
Users browsing this forum: Bing [Bot] and 51 guests
