1954 F
1954 F
Postby mickbooth » Wed Jul 13, 2016 10:17 pm
Anyone removed the engine from an F? Are there any tools that you need? Any tips appreciated.
mickbooth
Re: 1954 F
Postby jbcollier » Sun Jul 17, 2016 2:15 pm
Not many Fs about. I think you'll be the expert once you have the engine out.
jbcollier
Re: 1954 F
Postby Big Al » Mon Jul 18, 2016 7:40 am
Hello Mick. You could try the now-retired Lambretta guru, Howard Chambers in Southampton. He probably wouldn't want me to give out his telephone number here, but I feel sure that you could find it fairly easily.
Big Al
Re: 1954 F
Postby Steve J » Thu Jul 21, 2016 10:33 am
My guess (and it's only a guess) is that because the F has a torsion bar rear suspension, it may need a special tool to release the load of the torsion bar on the linkage before the engine can be removed. A bit like the D/LD rear suspension, but on the F it's all under the engine, including the linkage. I would not attempt to dismantle the linkage without releasing the pressure, as there's a good chance of damaging something that can't ever be replaced!
Steve J
Re: 1954 F
Postby Big Al » Thu Jul 21, 2016 4:43 pm
You could also try ringing Scooter Restorations in Nottingham, and/or Cambridge Lambretta Workshop for advice.
Big Al
Re: 1954 F
Postby mickbooth » Thu Jul 28, 2016 4:31 pm
Thanks for the suggestions, I'll see if I can make contact with Howard. Any more advice would be appreciated.
mickbooth
Re: 1954 F
Postby mickbooth » Sat Mar 18, 2017 9:48 pm
Coming together, just need to work out which of the two wires coming out if the stator goes to which wire on the loom.
mickbooth
Re: 1954 F
Postby mickbooth » Wed May 17, 2017 8:43 pm
All done. You don't need any special tools just a very large G clamp, some rubber pads to protected engine casing and a lot of patience.
mickbooth
Re: 1954 F
Postby jbcollier » Thu May 18, 2017 2:07 pm
Love to see photos!
jbcollier
Re: Lambretta F 1954.
Postby mickbooth » Mon May 29, 2017 7:36 pm
Photo as requested. Just awaiting the DVLA man and hopefully have it on the road in two weeks, subject to the weather!!!!
mickbooth
Re: 1954 F
Postby jbcollier » Tue May 30, 2017 1:55 pm
Beautiful !!
jbcollier
Re: 1954 F
Postby mickbooth » Fri Jun 09, 2017 10:23 pm
Visit from Mr DVLA on the 15/6/17. Looking forward to some nice sunny weather and see what's Little Mo's is like on the roads.
mickbooth
Return to Pre 57
Users browsing this forum: No registered users and 30 guests
