Leotech wrote:Ron told me the AF big bore tail pipe is too small and it would overheat. I asked about the AF twin pipe but he said that wouldn't work either.
I have toyed with making one. There are parts kits on eBay but I'd prefer a stub manifold and not a full u bend as these tend to come loose easier. It's a lot of messing about making one TBH and if I make it and it's a load of shite I'd be back where I started.
I have an Iron barrel PM pipe lying about but again it will be all Rev and clutch. I don't want that.
steveg wrote:Leotech wrote:Ron told me the AF big bore tail pipe is too small and it would overheat. I asked about the AF twin pipe but he said that wouldn't work either.
It's a longer story but I have a Ron Moss clubman that was built using a 48mm AF clubman as the doner pipe. Tail pipe on those is definitely big enough. Used it on my 230 Rapido for some years with no issues.
steveg wrote:I don't know because I didn't do it! I know Pete who made the early RM clubmans. He did one for me using a 48mm AF that I provided. He reworked it the same way. I had it from on my engines from 2010 until this year. I've now changed it as it was showing it's age and I didn't want it to fail.
