Hi chaps finally getting back round to building my dl 150 & after looking at kits I've decided on the GT 186, I'm looking at the delorto PHBH 30mm to go with it ,
Any thought on the above or anyone running a similar set up ?
Watto66 wrote:Hello
I have a GT 186 which I've done a couple thousand miles on in the last couple of years . I started with a 25mm dellorto with a AF clubman ran lovely however when I fitted a 30mm dellorto and a BGM clubman it transformed the bike totally I had it dynoed @ 20 BHP pulls like a train gives some if the standard TS1 lads a run . You probally need to beef the clutch up a bit I used Richard Taylor's springs they seem to work fine . I used the manifold from the GT 200 kit so it sits on the left side like a standard oh I didn't need to cut a hole in the panel. Hope this helps
burnside wrote:I'm running a PHBH30 with my GT186 and 60/110 crank, but with a Franspeed Race pipe and Li150 box 16/46, also running a GT200 with PHBH30,58/107 crank, BGM clubman and Li150 17/46. Both run really well although the pipes make them different animals
Vmakgp wrote:burnside wrote:I'm running a PHBH30 with my GT186 and 60/110 crank, but with a Franspeed Race pipe and Li150 box 16/46, also running a GT200 with PHBH30,58/107 crank, BGM clubman and Li150 17/46. Both run really well although the pipes make them different animals
Interesting burnside the franspeed pipes seem to have a good reputation , will have to take a look , I also like the look of the the Casa protti expansion , been put of the gori slitely with a couple of posts on hear ,regards baffle coming loose .
Vmakgp wrote:I like the sound of the super tour with the midrange power , just looking to see whose got the stainless steel one in stock .
