scootRS Tubeless Rims leaking Air
Postby drivera » Sat Jul 02, 2016 2:40 pm
Had 2 Dunlop scootsmart tyres fitted to some scootRS tubeless rims yesterday , I used the bolt in valves supplied and the buggers are leaking air around the rubber valve seats , had a word with the tyre fitter who suggested filling the tyre with green gunk ???
Seems a sh*t idea , but as the tyres are a pig to get off the rim any idea what I can do ??
drivera
Re: scootRS Tubeless Rims leaking Air
Postby col68 » Sat Jul 02, 2016 4:57 pm
Hi mate just had same problem with mine took them to bush tyres and had them removed and new pull in type put in cost me £11 for 3 wheels . col
col68
Postby drivera » Sat Jul 02, 2016 5:59 pm
Cheers Col , I'll give em a try in the week :)
drivera
Postby rossclark » Sat Jul 09, 2016 10:30 pm
I have a couple of ScootRS wheels that I fitted Bridgeport valves to. They're bolt in type and you need to remove a small portion of the rim above the valve hole and ensure the area where the valve sits is flat (file it) but they've not leaked at all.
Users browsing this forum: Google [Bot] and 65 guests
