lack of spark
lack of spark
Postby gp200ts1 » Fri Jul 08, 2016 3:10 pm
baffled with this one. finished a rebuild on my imola and it fired up ok. went to take it for a spin and in stopped about a mile from home. no spark. pushed it home and checked the readings from the stator and they are coming back within the tolerances. replaced the cdi with a known working one, new plug, new cap and new ht lead but still no spark. any ideas?
gp200ts1
Re: lack of spark
Postby gazza » Fri Jul 08, 2016 3:38 pm
What type of stator ? Was it new ? Maybe it's breaking down when it gets warm and when cold gives good readings. Also check flywheel magnets for damage
gazza
Re: lack of spark
Postby Raveydavey » Sun Jul 10, 2016 7:24 am
ignition circuit? You don't get a spark if the switch is set to off...I.e the key isn't in the slot. Try by passing it to rule that out. Check all earths are good too.
If neither of those, I'd put money on the stator/ cdi.
Raveydavey
Re: lack of spark
Postby jonno » Sun Jul 10, 2016 6:40 pm
I had similar and had to replace stator.Probably a burn out. SR about £36 tested.
jonno
Re: lack of spark
Postby gp200ts1 » Sun Jul 10, 2016 10:09 pm
Was a previously working stator. Anyway took it off and put my spare refurbished one on with bgm low tension coil and pick up. Fired 1st kick. Checking over the duff one and it turns out it's an intermittent earth. Resoldered and araldited it and it's a working spare again.
gp200ts1
Users browsing this forum: Majestic-12 [Bot] and 68 guests
