m7 nylocs
m7 nylocs
Postby Norrie Bodge » Wed Jul 06, 2016 12:16 pm
Seen these & thinking end-plate??
http://m.ebay.co.uk/itm/111855085961?_t ... 3641.l6368
Anyone using these? I'm thinking with flat thin washer & a dab ov Loctite??
Or are they too thick & the chain would catch ?
Norrie Bodge
Re: m7 nylocs
Postby Digger » Wed Jul 06, 2016 12:38 pm
What's wrong with the standard nut and spring washer?
Digger
Re: m7 nylocs
Postby ToBoldlyGo » Wed Jul 06, 2016 1:06 pm
Hmmm..... Heat, oil, nylon? Probably not good.
ToBoldlyGo
Re: m7 nylocs
Postby gaz_powell » Wed Jul 06, 2016 1:07 pm
I used to think that this would be good idea when I first started on lambretta motors having hearing tales of end plates coming loose. Having then stripped a few (2) engines that had used nyloc on end plate, some studs were drawn out, which then defeats the idea of studs. It did prove that you can get them in without fouling moving parts.
Similarly the use of high tensile bolts, again I toyed with idea but again dismissed it in favour of the original idea.
Personally I would stick with good quality studs, nuts and washers tightened in the correct sequence to the correct torque.
I've never had one come loose using the traditional method.
Re: m7 nylocs
Postby dscscotty » Wed Jul 06, 2016 1:31 pm
+1
Re: m7 nylocs
+1
Re: m7 nylocs
Postby a.lo » Wed Jul 06, 2016 10:37 pm
i dont think the problem is nuts coming off studs but studs pulling out hence the damage to the casing threads. i threadlock them in and have even used exhaust studs for extra thread
a.lo
Re: m7 nylocs
Postby Norrie Bodge » Thu Jul 07, 2016 9:55 am
Great replies, just a thought !!
I'll be sticking to the traditional method
Norrie Bodge
Users browsing this forum: Google [Bot] and 66 guests
