Jetting for 25mm Dellorto + S2 42mm Clubman
Postby Covboy » Mon Jun 20, 2016 8:55 pm
Hi all
I'm going to put my Casa 42mm S2 clubman exhaust on my S2 li150 this weekend.
Carb is new Dellorto 25mm phbl
Open mouthed at present ( I can't get a rubber elbow to fit properly on the standard ( but drilled) air box - the carb mouth seems too offset compared to the standard ones)
Has anybody got a similar set up and could advise what jetting to use as a sensible starting point?
Re: Jetting for 25mm Dellorto + S2 42mm Clubman
Postby Covboy » Tue Jul 05, 2016 8:10 pm
Ok no - one knows ! :D
What would be the starting point for the same set up but with a 42mm S3 clubman?? Any ideas?
Postby ULC Soulagent » Sat Jul 09, 2016 1:27 pm
Dellorto 25 phbl bs
Needle jet D26
AQ 264
Drum slide 40
Main jet 102
Idle jet 50
Choke jet 60
Float needle 200
Float 6.5
ULC Soulagent
Postby Covboy » Sun Jul 10, 2016 5:32 pm
Thanks !
Return to Carburettors
Users browsing this forum: Bing [Bot] and 40 guests
