by Jeff t » Tue Jun 28, 2016 10:23 pm
Just done a couple of jobs so new kick start and clutch springs, I also took the carb off and reed valve as I was getting a bit of spit back Imola with phbh 30mm, anyway put everything back and now it will start with the choke but soon as I turn it off it just dies. I was careful putting back together and the inlet manifold looks seated properly only other thought is if I could have damaged the reeds but like I said I was careful, any thoughts before I take it off to check.
Post by Jeff t » Thu Jun 30, 2016 10:14 pm
It's after a run there's quit a bit of shite on the running boards round the carb and on the inside of the side panel, it was more of just checking why I was doing a couple of other jobs. The only other thing is I left the carb cables connected and moved out the way to remove the reed valve but as per the posts I've checked all the obvious.
