Small block upgrade advice please..
Postby genolambo » Wed Jun 22, 2016 11:11 am
Hi all,
I'm currently building up the engine for my Li150 s3 resto.
I've acquired a GP150 case with GP200 gearbox and will be at 47/18 to keep the ratio similar.
What I would like is a little bit more power, just around town and the back lanes, so would appreciate your advice/recommendations for a cylinder kit and carb.
I would like to keep the setup as original as I can with regards to the carb through the airbox as it did originally.
So, a reliable cylinder kit and carb set up that uses the airbox is what I'm after. Just wanting a bit more power, just to keep up with traffic a little easier.
Budget wise, I believe you get what you pay for, within reason.
I realise there are similar questions posts with regards to this but I just wanted to make sure that anything recommended is suited to my set up. Apologies for that!
Any advice would be much appreciated.
Thanks in advance.
genolambo
Re: Small block upgrade advice please..
Postby ToBoldlyGo » Wed Jun 22, 2016 11:27 am
That sounds like my sort of riding. I have an engine with that exact same set up and it's fitted with a Casa 185 kit, which I can't praise enough. It sounds as if it might suit you, Sir. :lol:
ToBoldlyGo
Postby Meds » Wed Jun 22, 2016 11:51 am
Try this thread
viewtopic.php?f=7&t=3546
There is some good advice from Corrado about kits and state of tune.
My advice
If you have a tuner/dealer you trust, get their advice on what will fit your requirements.
No point in having a mismatched kit/pipe/gearbox
Meds
Postby genolambo » Thu Jun 23, 2016 10:11 am
ToBoldlyGo wrote:That sounds like my sort of riding. I have an engine with that exact same set up and it's fitted with a Casa 185 kit, which I can't praise enough. It sounds as if it might suit you, Sir. :lol:
Thats good to know :)
Does your carb through the standard airbox?
Thanks in advance
genolambo
Postby genolambo » Thu Jun 23, 2016 10:13 am
Meds wrote:Try this thread
My advice
Thanks, yeah that makes sense.
Cheers :)
genolambo
Postby ToBoldlyGo » Thu Jun 23, 2016 10:56 am
Thanks in advance
Yes it does Geno. I run it with a 22mm carb and a pretty ordinary clubman exhaust. Not the most exciting of set ups, but that suits me fine. It's smooth and nippy and pulls well. Really nice to ride.
ToBoldlyGo
Postby genolambo » Thu Jun 23, 2016 11:07 am
Thanks in advance
Sounds ideal for what I'm after. Thanks again :)
genolambo
Users browsing this forum: Baidu [Spider] and 70 guests
