jetex carb
jetex carb
Postby chips » Sun Jun 19, 2016 12:30 pm
Running a jetex carb. Sticker next to the mixture screw says keep max 3/4 of a turn. Do I ignore this? On a dellorto I normally start at 1 1/2 turns. Please advise. Thanks.
chips
Re: jetex carb
Postby johnnyXS » Sun Jun 19, 2016 2:28 pm
yes ignore that.
This is quite a good guide
http://www.mbscooters.co.uk/info/setting-up-*-engine-carbs-3/setting-up-*-engine-carbs-2+151.html
I always recommend setting the idle circuit first . Adjust the idle speed and air mixture screws until you have a stable idle before moving on .
johnnyXS
Re: jetex carb
Postby chips » Thu Jul 07, 2016 5:55 pm
I thought so, Cheers johnnyXS . :D
chips
Return to Carburettors
