SERIES 2 SIDEPANEL BRACKET
Postby Covboy » Wed Jun 15, 2016 9:25 am
Hi
Does anybody know of an outlet that sells the side panel catch bracket? My next project has got one missing.
If they're not available I will have to make one. :shock:
thanks...
Re: SERIES 2 SIDEPANEL BRACKET
Postby foremanbob » Wed Jun 15, 2016 9:54 am
I would suspect that you wont find them available
Either fabricate or put a want add up for a used part...
foremanbob
Postby Mel K » Wed Jun 15, 2016 10:21 am
There are so called remade ones available but I'd advise you don't waste your money on finding out what brand of cheese they're made from and fabricate your own . Or you could be lucky enough to find someone has an original they'd let you have . Good luck .
Mel K
Postby Digger » Wed Jun 15, 2016 10:31 am
As Mel said you can get them from Scooter Restorations but they are not fit for purpose.
I have one and it's half the thickness of the original, the wrong profile and just flaps around when you try and clip the panel on.
If you can make one I'm sure you'll have a ready market..... :idea:
Digger
Postby Kristof Lammy pie » Wed Jun 15, 2016 5:05 pm
I'm disappointed at the Scooter restorations ones are poor I need one for my Eibar, although I'm not surprised.
Has anyone used the series 3 panel clip set up on a series 2?
Kristof Lammy pie
Postby HxPaul » Wed Jun 15, 2016 5:18 pm
Covboy wrote:Hi
thanks...
viewtopic.php?f=10&t=2401&hilit=wheel+change&start=20 This post may be of some use
Postby gaz_powell » Wed Jun 15, 2016 5:31 pm
I did the API clip set up on my S2 as I didn't want handles. S3 don't work I had to make the clips.
Postby Covboy » Wed Jun 15, 2016 8:44 pm
Ok cheers fellas . I've posted a wanted but will probably have to make one
Postby xenia1 » Thu Jun 16, 2016 9:53 am
Theyre spot welded on so the only way youre probably going to get one is to advertise for a scrap/ accident damaged frame..
xenia1
Postby Digger » Thu Jun 16, 2016 11:14 am
xenia1 wrote:They're spot welded on so the only way you're probably going to get one is to advertise for a scrap/ accident damaged frame..
I actually took one off my Series 1 and sold it as it originally had no sidepanels.
Lesson learned - I seldom sell anything original anymore.
Digger
Postby xenia1 » Thu Jun 16, 2016 9:09 pm
Agreed, sods law always without fail kicks in and you'll need it at some point. Ive got a very large box full of used/rusty/ worn Tv1 parts that ill probably never use or have any need for....that is until i get rid of it all.... ;)
Great picture btw, the old phone boxes and letter box's always make a good back ground. Ive got a similar pair near to my place in the UK... my house is quite new but in a listed area so apparently cant be removed, getting quite rare on the ground now..
xenia1
Postby Digger » Thu Jun 16, 2016 9:22 pm
There's one or two left around here...... :)
Digger
Users browsing this forum: Baidu [Spider] and 73 guests
