drunkmunkey6969 wrote:Hi johnny XS, thanks for your feedback, always good to hear what people think and to get their responses to what we are doing in the magazine. Hopefully i can answer some of your questions and comments below.johnnyXS wrote:Is this to be an article about Bang for buck Tuning ....or an expensive scooter upgrade article ?
It is about bang for buck tuning, the clue is in the title. However in order to achieve bang for buck results, readers must gain some sort of knowledge, an overview if you will. Therefore, if Darrell runs a series of tests using lots of different components then he can deduce what is in fact 'bang for buck' and what is not. That gives the reader a better knowledge base for the reason to do A instead of B, and doesn't leave them wondering 'why didn't they try this?'.johnnyXS wrote:Anyone vaguely interested in this tuning series will either already have last months magazine or will make it their business to obtain a copy of the article.
No, not at all. The interesting thing about magazine buying trends is that you will have a hardcore (usually subscribers) who get every edition, and then a large 'glut' of readers who will buy say 6-8 editions per year, and a small number who will buy less than 6 editions per year. The idea is to give an overview for those who buy sporadically, its far more helpful that way, and doesn't compromise any information or facts for the regular reader.johnnyXS wrote:This is followed by a 3x page perfunctory breeze through a complete scooter upgrade ?
No, that's not an accurate assessment. It was a layman's guide to basic upgrades on the engine only, which is absolutely necessary if you want to take the engine to the next stage. To guide a reader through potential tuning techniques and not address basic upgrades would be ridiculous.johnnyXS wrote:‘In my garage we had a basic rule of thumb ‘ .....Just who is writing this article anyway?
I wrote it. Everything depends on available time for the magazine and the contributor. If Darrell is short of time i can visit, glean the info and report. If Darrell has time, he can write the report. The important thing for me is to get the info and the facts/results out to the reader.johnnyXS wrote:If it is a collaborative effort then it should say so .
It did, at the end of the article.johnnyXS wrote:At this early stage of the series it would appear to me that we are investing well over £1500 already in upgrades and I am left wondering just where our ‘Bang for Buck’ has gone ...
The engine upgrades to handle extra power are: Chain, sprocket, clutch plates, clutch springs, chain slipper, main bearings, oil seals, seal plate, con-rod/bearing. Circa £170 total. Darrell also fitted a better piston, not because it was needed at this stage, but for what is to come. I believe a nice piston starts around £90+
If you wish to fit a an expansion, which Darrell does in coming editions, you can buy something decent for as little as £160
At this stage all tests were run with a small/standard carb which was up-jetted, but Dellorto cabs start from as little as £89.
So everything is about choice, stages: If you want to simply 'adjust' your engine and fit no components then Part 1 of the series is for you, if you want to test a few bolt-on/bolt-off components, then Parts 2 & 3 might suit you, and if you want to start porting cylinders.....then keep reading!
As for bang for buck, its all relative, especially compared to some of the current kits and hi-spec engines out there.....the tuning carried out is about as frugal as you can get per bhp gained, so i hope we are not doing too badly with the feature. Darrell will run a lot of tests, they need not all be considered 'instructions' in the sense of a step 1, 2, 3...but as a series of research articles to show what works, and what does not. The choice is then left with the reader, and they should have sufficient info to help shape their choices.
I hope you enjoy the coming editions
I haven't seen a copy of scootering for about a year so don't know if what I'm about to say is a fact or not but it would be much better imo if the articles about tuning had input from as many different "tuners" as possible rather than from one or two.
johnnyXS wrote:sorry but this is utter rubbish !
if you are going to criticise another members opinion then at least have the courtesy to get your facts right .
johnnyXS wrote:First of all the very first upgrade you mention in the second article is an expansion exhaust. I cannot find any to be had in the UK below £250 which makes your statement of the total upgrade costs being less than £170 nonsense.
johnnyXS wrote:exhaust c £250.00+
The two Koyo crank bearings c £60.00
Wossner piston and ring kit c £110.00
Yamaha rod and bearing kit c £120.00
caburettor upgrade ?? c £100+ ??
Boxenstop brake kit c £55.00
Eden wrote:I haven't seen a copy of scootering for about a year so don't know if what I'm about to say is a fact or not but it woukd be much better imo if the articles about tuning had input from as many different "tuners" as possible rather than from one or two.
From what I have heard and read around the Internet it seems Darrel's opinion is seen by scootering magazine as being the only one that counts, when infact there are many different trains of thought on the subject.
Apologies if there is input from other "tuners" in these articles.
Knowledge wrote:A good reply Dan
Expansions can be bought for as little as £150: http://www.ebay.co.uk/itm/LAMBRETTA-SER ... SwxcRW8pBn
However the one Darrell used in his test is the TSR Evo exhaust and the retail price is indeed £169.99 https://www.thescooterrepublic.co.uk/la ... hausts-c58
Koyo crank bearing kit is £33 http://www.ebay.co.uk/itm/KOYO-Japanese ... SweW5VUj1S
I'm sure you're right about the cost of a Wossner, although other pistons are available for £90+
Conrod kits are generally £30-£40 http://yambits.co.uk/rd350-ypvs-conrod-kit-p-12057.html
I sold Dellorto 25, 26 & 30mm carbs for the past 6 years, i always sold them for £89.95
Boxenstop is indeed circa £55, but that is optional...a decent set of rear shoes from Beedspeed, MB, Chisel (or other ) will be less than £15...and as long as they replace the standard SIL item, that is all that matter.
So the base upgrade items are indeed circa £170 ....but we digress!
Its unfortunate if you didn't enjoy Part 2 as much as you did Part 1, they often say the squeal is never as good as the original...lol....![]()
Hopefully your faith will be restored in Parts 3 & 4
Eden:
Somender SINGH springs to mind, how many of you have heard of him or heard of his groove theory? its quite old now but still argued about
Warkton Tornado No.1 wrote:
PS Shhhhhhhhhhhhhhhhh! Dan! Is that alright? Can I have that job now?
by drunkmunkey6969 » Wed Jun 15, 2016 3:53 am
Almost perfect Mark, you just forgot to tell everyone to subscribe to the mag and provide a link to a subs offer......
by CHRIS in MARGATE » Wed Jun 15, 2016 8:47 am
Personally I think having the editor posting on this forum and sometimes having to defend his publication of a magazine that some regard as "marmite" to be a very brave and honest approach.
It was after reading about the changes at "Scootering" over on Scooterotica that I decided to buy it for the first time in many years. This was almost certainly down to your enthusiasm and honesty. I enjoyed it that much that I will be ordering a back copy to catch up with previous articles.
Tuning ? Well in my little world I consider that I am the best but that's only best for what I want, nobody else. I have been experimenting for over 45 years with a good level of success and a good number of disasters.
I think Mark's quote relating to a 3 piece suite supplied from different sources sums it up for me. I personally dont think that there is one tuning supremo who stands head and shoulders above all for all states of tune but there are certainly a high number of genuinely acclaimed and proven tuning gurus that will deliver a tune to your requirements. There are basic rules that all tuners have to follow and for the road there has to be built in longevity and reliability so as per the latest issue changing the weaker components has to be the starting point.
I will now continue to buy and read the magazine and if it enters a period when I believe that it is of no further value to me, then I shall withdraw my support but in the meantime keep up the excellent work Dan, if I may call you Dan and keep delivering an improved magazine that "nobody" reads but still know the entire contents of. Yeah right !
Eden wrote:, my initial point about the scootering article was that other people's opinions would bring some ballance. Obviously from the two or three replies to that in this topic it seems I'm alone in that opinion .
Post by Eden » Wed Jun 15, 2016 11:20 am
Interesting points of view.
I reserve my judgment of who's tunes are good by how many of their motors put in successful miles year in year out doing "fast" long distance miles rather than who's tunes put out the most BHP.
Imo and it's only my opinion, there are many more people who have fast tunes who never ride more than 50 miles in a day. These tuned motors are often tuned for these people knowing the motor will never be expected to sit on a motorway at 70 mph for 500 miles in one day so the tune can be much closer to the edge than a motor tuned for killing miles rather than MPH.
Horses for courses and all that, my initial point about the scootering article was that other people's opinions would bring some ballance. Obviously from the two or three replies to that in this topic it seems I'm alone in that opinion which is good news for the magazine as it's obviously appealing to the masses which to survive it has to do.
One day I might buy a copy, who knows.
Post by Eden » Wed Jun 15, 2016 5:48 pm
Actually, few Forum users outside of track racing would be aware that Mark Ellis built a Group Four with some very pioneering ideas, as I recall. This was quite some time prior to 2010.
He wrote an article (or two) for Scootering magazine in which he outlined some of the features.
Maxton were commissioned to re-valve a Honda RS125 rear shock & his MSC motor used a Keihin PWK, if memory serves.
In the hands of Scott Swarbrick, that bike was unassailable in its class.
people have used Keihin pwk carbs for years, the airstriker is quite different.
Eden wrote:A quick search to show the difference, have a read here.
http://www.trx250r.net/forum/intake-fue ... riker.html
basically the A/S has fins in the mouth which non A/s don't have and they are quad vented, they were made to provide better running through 1/4 throttle and I can confirm that they do just thatPWK ... Came After the "PJ" Oval... the "Oval" Carb. was to replace the "Round" OLD Carb's. .. the reason for the "Oval" is because Mic. had the Patent on the "Flat" Slide Carb. .. the Oval has the Choke Circuit in with the Idle and Allow's fuel to "discharge" after you let off at a HIGH Speed ...Unlike the EXPENSIVE Lectron Carb's ... Later on "They" Came out with the ....... "PWK" ... A BETTER Responsive Carb."because of the back "D" (Flat) Part of the Slide.....( a way to BETTER it because of the Patent ) !! ...
the PWK A/S..."Air Styker" Carb's have TWO Fin's in the Rear Bell of the Carb. for More "MID." Punch ...
the PWK Q/V " Quad Vent " has TWO Extra Hoses Routed up and around each side of the Carb. for the "WHOOPED" Section...the Bike won't "BOG" as Much because of this !!
the PWK-A/S-Q/V "Air Stryker,Quad Vent" is for the Moto-X Racer in Mind ..LOT'S of Low and Hard Mid Punch .....
here is a pic of the one on my 240
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
