I want to change my Augusto 6000 box to an 8000,do I need to adust the timing currently set up at 17 deg?
CHRIS in MARGATE wrote:At what RPM do you cruise for long periods. You won't be holding at your highest rpm for more than short bursts I am assuming. I set my 6000 so that I would feel 100% comfortable when holding it at somewhere between 5500 and 6000 for long periods. Watched it on the strobe and my tacho.
I would need to feel "comfortable" that my 8000 was not overly advanced at my cruising rpm if you get my drift.
