by Lambo » Thu Jun 09, 2016 7:49 pm
Hi
can I use a sil 200 mag housing in my small block engine casing and if so, do I need to alter any thing? Mine's damaged and needs replacing, I have a new sil GP 200 housing that I could use or should I try and get hold of a small block housing?
noob here so all advice gratefully received, cheers.
Lambo
by petemaisey » Thu Jun 09, 2016 8:18 pm
The 200 housing will fit and work perfectly well. The cut away that guides the petroil mixture into the transfers is slightly larger. If you were using a small block flywheel housing in a 200 engine you may have a problem with the barrel skirt touching and again a mismatch at the transfer.
Pete
petemaisey
by Lambo » Thu Jun 09, 2016 8:51 pm
Cheers Pete, appreciate the advice.
Lambo
Users browsing this forum: B1gD0gu3 and 13 guests
