Rt performance
Rt performance
Postby gp200ts1 » Fri Jun 03, 2016 9:12 pm
What sort of performance are people getting out of the rt190 kits. Blown the imola again so looking to go rt190 with bgm clubman and 30mm dellorto
gp200ts1
Re: Rt performance
Postby Mel K » Sat Jun 04, 2016 8:52 am
Fitted with a 60mm crank a mates one kept up with TS1's at a genuine 70 + mph for a good few miles on the recent South Downs run .
Mel K
Re: Rt performance
Postby rexton270s » Sat Jun 04, 2016 9:59 am
my friend and i took our scooters for a dyno,his is a rt195 28mm delly static timing,and af clubman,11 bhp 8.7 torque! :? mine is a mugello 186 (116conrod) 30mm delly varietronics,jl4! 18.7bhp 13.8 torque! both ride from clitheroe to harogate, his took 4.5 ltrs, mine took 5.2 ltrs! his is a pacemaker box mine is a tv175 box (4.82) the rt seams to coupe well on the hills but my mugello is never far behind,straight line speed the mugello is quicker by far! v4 mugello!
rexton270s
Re: Rt performance
Postby Adam_Winstone » Sat Jun 04, 2016 11:16 am
All depends on what you think of as performance. The power delivery and 'performance' of different kits can differ massively but both have excellent performance for their intended function. Comparing a revvy high BHP kit to a low revving lower BHP touring kit is a bit like trying to consider which performs better a Ferrari or a Land Rover? Without any changes to the vehicles in question, change the intended purpose; high speed autobahn 400 miles or 400 miles through the desert or up the side of a mountain?
You need to apply the right motor/kit to the application that you want it for.
Adam
Re: Rt performance
Postby Bofs » Sat Jun 04, 2016 11:20 am
I`d suss what`s blown your Imola`s first or the RT will go the same way.
Bofs
Re: Rt performance
Postby gp200ts1 » Sat Jun 04, 2016 10:00 pm
Looks like the head I had fitted was too high compression. Looks like it was a reaper head. It was a used kit that I had picked up. Jetting was roughly what I have on my other identical motor apart from the head it was all the same. Stripped it down and no evidence of air leaks just the piston holed. Barrel is unmarked so it looks like a new piston and genuine head and I should be good to go. Stripped the bottom end, cleaned it out and rebuilt using new seals and mag gasket. Just waiting on new parts and it will be good to go
gp200ts1
Re: Rt performance
Postby Feersum Injun » Mon Jun 06, 2016 2:18 pm
Mel K wrote:Fitted with a 60mm crank a mates one kept up with TS1's at a genuine 70 + mph for a good few miles on the recent South Downs run .
After a little more tweeking of the carb it's running even better now than at South Downs. Had a blast down the M53 last week and it tops out at just shy of 70 (69.7 to be precise!). Going through the gears it hits around 48 in third. And as South Downs proved it gobbles up hills. I can't compare to other kits but a few people commented on it's performance that weekend. I'm happy!
RT195 with MEC 60/110 crank
28mm Delly, 42mm AF clubman
AV268 / X13 2nd clip / 118 main / 53 idle
Feersum Injun
Users browsing this forum: No registered users and 48 guests
