soulfecker wrote:You say you have a std li lever, have you a clutch bell with the spigot that goes into the Christmas tree. If not, then the bell may be canting over. I had this problem, and had to convert to a gp type bell, side casing and clutch lever.
Paul
Warkton Tornado No.1 wrote:Your kick-start inner could be catching the clutch top plate but only when you kick it down.
If you set the clutch cable play to what would be ‘normal’ with just a little free play, does it bump start alright?
it kicks starts fine when i adjust the cable to suit but then i get bad clutch drag so i have to set the cable so the kickstart just works then i get minimal clutch drag
terryj wrote:but i set the clutch arm up at 90 deg and just touching clutch then tighten cable to suit so i assume if i replaced thimble and arm it would still be
Users browsing this forum: Google [Bot] and 48 guests
