Cylinder head?
Cylinder head?
Postby Lammer205 » Sun May 29, 2016 11:51 pm
Is a cylinder head that came with a kit which had a 30mm crown height piston ok to use with a piston with a 39mm crown height? Lammer205
Lammer205
Re: Cylinder head?
Postby rossclark » Mon May 30, 2016 12:26 am
Should be, but check the profile of the piston crown to the head and confirm the squish setting.
You should also check the final compression ratio.
Re: Cylinder head?
Postby Lammer205 » Mon May 30, 2016 7:53 am
Thanks for that ,Yeah it's 9.1 comp ratio will check squish and try it hopefully be ok.Lammer205
Lammer205
Re: Cylinder head?
Postby gaz_powell » Mon May 30, 2016 9:25 am
If is a purpose made lam piston ie racetour/bgm, af wosner etc then yes as they use the same crown profile as traditional lam, but it jap you will have to rework the head profile. I had to on my yam it 175 in a ts1 and in a malossi 172 with a suzuki ts185 in a vespa.
And as said always check the squish.
Re: Cylinder head?
Postby Lammer205 » Mon May 30, 2016 9:31 am
Yeah going from MRB to Wossner just different crown heights so you think ok?Lammer205
Lammer205
