MickYork wrote:or try it a tad lean and fit a filter ?
Maybe a dyno would be an easier option ?
The washer sits flush in a recess in the slide the top of which seems level with the surface the clip sits on.
Atomiser and needle are about 1000 miles old so wouldn't have expected any noticeable wear?
I wish I could say I knew what you meant by a plunger to keep the needle in line. There is nothing like that in this carb.
as for the spacer for under the needle clip, are these not simply a thin washer?
Regardless of the recess in the slide which the washer (really a shim) fits into, it still spaces the needle clip up by the thickness of the shim.
Regarding the plunger thing. I can see the brass item sunken in the hole in the slide; how does it work? There doesn't seem any means of moving it.
Users browsing this forum: Bing [Bot] and 29 guests
