coaster wrote:That's not filling me with hope Peach, the Vega I just bought doesn't have a log book either...I do believe the frame and engine numbers match though but can't confirm until I pick it up.
MK Monty wrote:After reading a post on here about series 1 frame numbers I got the v5 out and found bugger that's not a series 1 frame number at all. It was a series 3 number. Now like the wife the old girl may have put on a few pounds but no was she ever slim.
The engine number was correct the actual frame number was unmolested and it took a lot of letters and frame rubbings and an inspection before I got a revised V5. I was advised that a lot got screwed up when they went digital they even pulled the microfilm and that was wrong also. But they could only go back so far as all the original paper docs were long gone. The q plate threat was also used on the lines of let us do our job and I should just say ok. Took close to 6 months
Rich Oswald wrote:MK Monty wrote:After reading a post on here about series 1 frame numbers I got the v5 out and found bugger that's not a series 1 frame number at all. It was a series 3 number. Now like the wife the old girl may have put on a few pounds but no was she ever slim.
Late Series 1's and early Series 3 LI 150's have the same numbering sequence which sometimes give me real headaches without seeing a pic' of the scooter itself.
Angry Bloke, I am surprised that DVLA are even considering letting you have the old Reg' number without any documentation and even then you have to go down the V765 route (re-claiming old reg' numbers) which Jain deals with. If you get no joy with DVLA then I suggest you get a Dating letter from myself and go down the first registration route and get an age related plate to avoid the dreaded Q plate.
Angry Bloke wrote:coaster wrote:That's not filling me with hope Peach, the Vega I just bought doesn't have a log book either...I do believe the frame and engine numbers match though but can't confirm until I pick it up.
You should be OK as you are registering an import - my problem is that the numbers don't match the DVLA records ....... For whatever reason !!
coaster wrote:Well I have the numbers now, it has a K plate and a frame number beginning 20/8*652 and an engine number beginning 75S*652 the final 3 numbers are about 390 apart. Reg. doesn't show up on the DVLA website
Rich Oswald wrote:coaster wrote:Well I have the numbers now, it has a K plate and a frame number beginning 20/8*652 and an engine number beginning 75S*652 the final 3 numbers are about 390 apart. Reg. doesn't show up on the DVLA website
That, according to my records should be a 1968 Vega 75 on an F plate. Possibly sat in showroom for four years?
coaster wrote:Rich Oswald wrote:coaster wrote:Well I have the numbers now, it has a K plate and a frame number beginning 20/8*652 and an engine number beginning 75S*652 the final 3 numbers are about 390 apart. Reg. doesn't show up on the DVLA website
That did used to happen, a friend of mine bought an SX200 in 1971 that had stood in a showroom in Felixstowe since 1968I guess that's what the GP did for sales of the older models.
Was the Luna range available in 1968 (F), I though 69/70 so H or J maybe
coaster wrote:I've just submitted my V62 with a £25 cheque, I hope I used the correct VIN numbers as there were insufficient boxes for all the numbers, I had to leave the 20/8 offI did put a photo of the whole number in the envelope though.
Sorry for the hi-jack Peach but it's all relevant
Users browsing this forum: No registered users and 83 guests
