by Strummer10 » Sat May 07, 2016 6:07 am
Does anyone know 1/ whether you need to Dremel out the engine case to match the barrel to the case on a Muggy kit or not ? and 2/ Ideal squish required and 3/ Ideal timing setting ........thanks in advance
Strummer10
by rossclark » Sat May 07, 2016 9:34 am
Thoughts -
1. You don't HAVE to but it can improve gas flow to the transfers.
2. 1-1.5mm not less that 1mm though.
3. 17 degrees BTDC if you're running static timing would be in the ball park.
by bazza3004 » Sun May 08, 2016 12:24 pm
^^^agreed^^^
bazza3004
by Strummer10 » Sun May 08, 2016 2:10 pm
thanks guys
Strummer10
