PM tuning speedo drive
Postby Toddy » Wed May 04, 2016 10:01 pm
Anyone got a PM single disc hub set up on their scoot or in the garage I have a lads to put together with a new speedo drive but struggling to see how it goes together any close up pictures would be great to see how it goes
Cheers Toddy
Re: PM tuning speedo drive
Postby carlos fandango » Thu May 05, 2016 12:15 am
carlos fandango
Postby Toddy » Thu May 05, 2016 6:09 am
Cheers Russ a bit blurred but can nearly see what i need lol , the Tab on the speedo drive does it need to be bent/shaped into a U type to sit in the recess on the hub ?? you can see it on your pic on the R/H side
Postby jonashford » Thu May 05, 2016 6:03 pm
t shud be bent in a u shape and it sits in a little slot on the hub, quality control at pm isnt great, they send all sorts of bits out with those front hubs
jonashford
Postby hullygully » Thu May 05, 2016 6:07 pm
mine's on the other side matey, make sure you don't break the tab cos they scr*w you for a replacement!! :shock:
Postby Toddy » Thu May 05, 2016 7:52 pm
jonashford wrote:t shud be bent in a u shape and it sits in a little slot on the hub, quality control at pm isnt great, they send all sorts of bits out with those front hubs
That sounds right John
Users browsing this forum: No registered users and 52 guests
