Wack wrote:I use a piece of plastic pop bottle and grease to slide the seal in.
Wack wrote:Yes, just cut a strip out of a litre bottle of pop( thinner plastic than a small bottle) wrap it around the layshaft and bearing inner track, grease and slide the seal over it with your thumbs. Once fully in, pull the sleeve out. This way there's less chance of rolling the seal and flicking the spring off.
Users browsing this forum: Google [Bot] and 42 guests
