by Lammer205 » Tue Apr 26, 2016 10:22 am
Hi , is there an easy way to tell if a barrel is from a Tv175, or a normal 175 conversion barrel? thanks Lammer205
Lammer205
by rossclark » Tue Apr 26, 2016 10:32 am
I'd have thought a genuine TV barrel might be longer to accommodate the longer rod.
What is the distance between the gasket faces?
by Lammer205 » Tue Apr 26, 2016 11:48 am
Hi distance between gasket faces is about 101mm. thanks Lammer205
Lammer205
by Adam_Winstone » Tue Apr 26, 2016 1:01 pm
Barrel length is the same as other SIII barrels (although there are some very minor length differences between models) as the longer rod is used with a lower compression height piston, resulting in the same overall piston height at top dead centre.
Do a search for identifying different barrels as there have already been a number of threads on the subject.
Regards,
Adam
by Wack » Tue Apr 26, 2016 6:17 pm
Looking at 2, both have cut outs on the spigot and 2 notches on the top fin. One has a number 3, the other 0 on the stub next to the inlet and both have a half moon shape on the head gasket face.
Users browsing this forum: Google [Bot] and 49 guests
