Rattle and hum....
Rattle and hum....
Postby Storkfoot » Sun Apr 17, 2016 7:29 pm
.......when you're flying along on a nice day and you hear a noise that could well be pinking, don't tell yourself that it couldn't possibly be pinking, it must be a rattle from somewhere. Otherwise, within a few minutes you'll hear a "pop" and you'll be grabbing the clutch............
Re: Rattle and hum....
Postby Wack » Sun Apr 17, 2016 8:12 pm
Oh dear, air leak on head the cause?
Postby steveg » Sun Apr 17, 2016 8:24 pm
Not good Paul :o
steveg
Postby Storkfoot » Sun Apr 17, 2016 8:36 pm
The head was leaking into the studs but not right out which is why I didn't spot it. Looking at the cylinder head in the photo, it looks to me like it has been like this for a while.
Also, I run with a RamAir filter straight on to the plastic bellmouth of the PHBH and out through a hole in the panel. The bellmouth had vibrated loose (threads knackered) with the Ram Air still attached. Whilst it hadn't actually fallen off, I suspect it was drawing in more air than normal.
This is actually the first holed piston I have ever had (I've had plenty of seizures on cast iron barrels :P ) so mustn't grumble. Bits of aluminium get everywhere, crank, reeds, bearings, seals.
I'm planning on flushing out the bearings and replacing the seals. Is that reasonable?
Postby Storkfoot » Sun Apr 17, 2016 8:38 pm
steveg wrote:Not good Paul :o
Aye, mate, just when you could do without the expense too. It was on the way from Llangollen towards Chester after a very pleasant weekend :D
Users browsing this forum: Baidu [Spider] and 73 guests
