PHBH Needles
PHBH Needles
Postby coaster » Sat Apr 16, 2016 1:07 pm
Just playing with my carb settings at the moment on mu TS1/30PHBH/Franspeed Supertourer as the hand choke is not having the 4 stroking effect that it used to :? I currently have an AV266 with x7 on the 2nd clip from the top. I also have an x2 and an x13 but I'm not sure which is richer. Information on the net is contradictory :?
Colin
Re: PHBH Needles
Postby Angry Bloke » Sat Apr 16, 2016 1:36 pm
Hi Colin - X2 is richest , then X13 ,X7 is leanest
Angry Bloke
Re: PHBH Needles
Postby coaster » Sat Apr 16, 2016 1:40 pm
Angry Bloke wrote:Hi Colin - X2 is richest , then X13 ,X7 is leanest
That's what I Peach but there are some contradictory websites out there so thanks for confirming. Do the needles HAVE to be paired with specific atomisers?
Colin
Re: PHBH Needles
Postby Angry Bloke » Sat Apr 16, 2016 1:50 pm
Colin
No it's not essential but common pairings are
X7 - AV 262
X13 - AV 264
X2 - AV 266
Angry Bloke
Re: PHBH Needles
Postby coaster » Sat Apr 16, 2016 2:01 pm
I think I cracked it with the needles, I'm now realising that the length measurement refers to the length of the taper not the length of the whole needle :roll:
Re: PHBH Needles
Postby Nelly » Sat Apr 16, 2016 3:41 pm
There's some valuable info on the Bristol Lambretta website.
http://www.bristollambretta.com/dellort ... eedles.htm
Nelly
Re: PHBH Needles
Postby Adam_Winstone » Sat Apr 16, 2016 5:05 pm
... or the other way around:
X7 with AV266
X13 with AV264
X2 is the next getting richer but I've never used one so have no experience of atomiser combo.
Adam
Re: PHBH Needles
Postby Adam_Winstone » Sat Apr 16, 2016 5:09 pm
NB: ^... These are typical combos, not hard and fast rules! You should combine them as per the needs of your motor, rather than use the suggestion as more that a starting point. Also note that I've found many needles to be very different in reality from what the spec sheets say they should be, e.g. all of these needles should have the same shaft diameter and tip diameter (only taper length varies), however, I've found that they can vary on the shaft diameter can be either bigger or smaller than specified, meaning that atomiser requirement may vary.
Best of luck.
Adam
Re: PHBH Needles
Postby Angry Bloke » Sat Apr 16, 2016 7:35 pm
Adam_Winstone wrote:... or the other way around:
X7 with AV266
X13 with AV264
Adam
Sorry Colin - Adams correct 8-)
I'm running a X7 / AV266 on my Avanti
Angry Bloke
Re: PHBH Needles
Postby Norrie Bodge » Sat Apr 16, 2016 8:51 pm
this will help you
Norrie Bodge
Re: PHBH Needles
Postby Norrie Bodge » Sat Apr 16, 2016 9:15 pm
Norrie Bodge
