Rear Brake Help Please
Postby devlam » Tue Apr 05, 2016 6:36 pm
I wonder whether any of you can help with this please. Prepping for MOT on new build. New rear hub and shoes cables etc. I'm struggling to get good adjustment on the new set up. I had to fix the rear brake arm quite a way forward before doing up pedal clamp to get anywhere close to reasonable adjustment, but I find now that the brake arm seems to be sticking on. It's not related to the cable as when I release the pedal there is play in the cable. If I push the arm back it seems to click free. I'll take a look tomorrow but if anyone has any thoughts I'd be much obliged.
Cheers, Mark.
devlam
Re: Rear Brake Help Please
Postby Tony Hart » Tue Apr 05, 2016 6:40 pm
Hi. Sounds like the brake-cam is going over centre. Do you have the correct brake shoes fitted - the GP and LI ones are different to work with the different brake cams
Tony
Tony Hart
Postby Granty » Tue Apr 05, 2016 7:40 pm
I had this same problem, it was the brake cam moving to far to engage the brake and jamming on, when I released it there was too much play in the cable,tightened the cable pedal end and greased the cam where it engaged with the brake pads,lightly mind on the grease, no probs again,G
Granty
Postby devlam » Tue Apr 05, 2016 7:56 pm
Thanks for that -- It's a new uni hub, the shoes are Li and the Brake Cam is the original Li. Based on your suggestions I guess also that the cam could be worn then. Will look tomorrow. Thanks.
devlam
Postby Norfolk » Tue Apr 05, 2016 10:42 pm
On my scoot there is a thin clip that fits around the brake cam onto which the brake shoes rest, in effect making the cam larger and enabling the brake shoes to fit closer to the brake drum. In my opinion it is too good a fit to be a bodge that someone fitted in the past
Norfolk
Norfolk
Postby Knowledge » Tue Apr 05, 2016 11:04 pm
Isn't there something about ensuring the cam is the right way round? I think there is a punched indent on the cam which shows which way round it should be (indent facing up?)
Postby CHRIS in MARGATE » Wed Apr 06, 2016 7:42 am
Norfolk....that's probably GP set up.
Postby Norfolk » Wed Apr 06, 2016 10:19 pm
Sorry, Chris in Margate,
1964, Li series 3,
Norfolk
Norfolk
Postby CHRIS in MARGATE » Wed Apr 06, 2016 10:27 pm
OK with LI cam and brake shoes ?
Postby Norfolk » Wed Apr 06, 2016 11:11 pm
To the best of my knowledge :roll: i have only changed the shoes, the cam and clip are original, well since I brought the scoot in 1978 for £35.
Norfolk
Norfolk
Postby Wack » Thu Apr 07, 2016 5:27 pm
One to watch is the cam hole isn't worn oval in the casing.
Postby devlam » Thu Apr 07, 2016 6:08 pm
So I've taken it apart and the cam is definitely hanging up on the corner - tried a bit of grease but still no good. I'm going to try replacing with a GP cam and shoes.
devlam
Postby MK Monty » Thu Apr 07, 2016 7:42 pm
Have you still got plenty of meat on the shoes. New shoes are normally a tight fit getting the hub on. If they are worn you can go past the cam point of return.
MK Monty
Postby devlam » Fri Apr 08, 2016 6:58 pm
Changing to GP shows and cam seems to have fixed it. I think the Li shoes were possibly not best quality - cam seems to have indented the contact point on the shoe and I think this is where it was sticking. I still don't have wonderful stopping power but will let them bed in and adjust. Thanks for the hints.
devlam
