Fitted Ancillotti Seat - remove baffle in air scoop?
Postby davla » Tue Jul 22, 2014 1:20 pm
I've just fitted a Scootopia Ancillotti seat which all but obstructs the air-intake. I'm thinking of removing the baffle in the air-scoop to improve airflow, does this sound like a good idea? It's a standard 150 Special with 18mm Dellorto.
davla
Re: Fitted Ancillotti Seat - remove baffle in air scoop?
Postby St George » Tue Jul 22, 2014 5:44 pm
I think that some Spanish models were made without that part, they all work.
St George
Postby HxPaul » Tue Jul 22, 2014 6:00 pm
St George wrote:I think that some Spanish models were made without that part, they all work.
GP 150's and GP 200's didn't have the baffles in the air-scoop presumebly to get more air into the 22mm carb.
Postby landybretta » Tue Jul 22, 2014 6:57 pm
Removing the air scoop baffle is not a problem but you may have to alter your jetting.
Just check your plug colour if you go ahead.
landybretta
Postby davla » Tue Jul 22, 2014 8:46 pm
Yeah but the Spanish airflow is fed through the louvres in the toolbox door.
I've chopped out the restrictor/baffle thing anyway.
davla
Postby St George » Thu Jul 24, 2014 4:44 pm
The later Spanish models had a kidney shape air box albeit, the hole for the intake is under the seat like my Italian GP 200.
St George
Users browsing this forum: Baidu [Spider], Google [Bot] and 77 guests
