Atomiser differences
Postby stonerosesmod » Thu Jul 17, 2014 5:59 pm
I say chaps, whats the difference between an AV266 and an AS266 atomiser in a phbh carb?
stonerosesmod
Re: Atomiser differences
Postby DaveTomo » Thu Jul 17, 2014 6:36 pm
DaveTomo
Postby stonerosesmod » Thu Jul 17, 2014 6:50 pm
Cheers Dave,a mates bought a second hand muggy 200 engine and the jetting looks fine when i checked the carb today.It starts but is really lazy revving and dripping fuel from exhaust manifold so im gonna check the timing next.
stonerosesmod
Postby paul213 » Tue Jul 22, 2014 11:35 am
The av atomiser is 2mm shorter at the top where it enters the venturi of the carb . this has the effect of weakening the mixture as the needle sits further into the atomiser .so an AV266 will give a richer mixture against an AS266 at the same clip position on the needle.
hope this helps
Paul
paul213
Return to Carburettors
