Rich Oswald wrote:If you want standard performance then why are you changing to a Clubman? If you really must change then why not try one of the new Scootopia 22mm Del Orto copies. You will, as has been said, have to increase your air flow via the scoop.
wibblethorpe wrote:If the motor is running the factory TV 200 gearbox & barrel fitting a larger 22mm carb & clubman could make pulling the tall g/box ratio a chore.
My understanding was the larger carb & changes to the exhaust for the GP made for a revier motor hence g/box ratio change(5.2 as opposed to 4.4).
missing lynx wrote:thats what I said lol
Warkton Tornado No.1 wrote:paulLI
I can see your objective was to ask opinions concerning optimising what you already have.
Users browsing this forum: No registered users and 47 guests
