Gear wheel ? Plastic ?
Postby St George » Thu Mar 24, 2016 4:50 pm
I have just reassembled my lower headset ( Serveta late series 3 ) which has been painted. I took this apart months ago when it was warm enough to work in the garage. I re-fitted the plastic gear-wheel but have mislaid what held it onto the shaft. I cannot remember if it was a small nut and bolt or was a pin driven through with an interference fit. In Sticky's manual they all seem to be brass gear wheels. Any help would speed up my MOT, thanks.
I did not start this thread in the Spanish section as it does not seem to get used much.
St George
Re: Gear wheel ? Plastic ?
Postby coaster » Thu Mar 24, 2016 4:58 pm
It will be a metal 'roll pin' not a nut and bolt.
Postby St George » Thu Mar 24, 2016 5:02 pm
That's what I thought, I must have driven it down into the Horncast. Where the hell do I get one of those Easter. Thanks for reply.
St George
Postby Adam_Winstone » Thu Mar 24, 2016 6:38 pm
The roll pins are crap and often come loose, which has prompted me to drill the rod on a number of mine and then secure the wheel with a suitable screw.
Adam
Postby Knowledge » Thu Mar 24, 2016 6:58 pm
I appreciate that this reply won't help you for this weekend, but I always opt for the metal gear wheel on a splined control rod. I then weld the "spade" at the left hand end onto the gear change in order to eliminate as much slack as possible at the top end of the gear change "chain".
Postby Tractorman » Thu Mar 24, 2016 8:53 pm
You should get a pin at a motorcycle shop, motor factors or smaller car repair garages. You could try a spirol pin or mills pin instead of a roll pin. Roll pins usually come loose because they are fitted incorrectly, the pin should not be fitted so the turning force can close it.
Postby holty » Thu Mar 24, 2016 9:06 pm
Adam_Winstone wrote:The roll pins are crap and often come loose, which has prompted me to drill the rod on a number of mine and then secure the wheel with a suitable screw.
Adam
i tap the hole, then put a bolt though the wheel hole and tighten it up on the rod, drill the hole in the gearwheel so the bolt will pass though, you can do the same with the metal wheels to give less flex,i do both wheels, also the bolt cant fall out, much like adams fix.
holty
:D
holty
Postby missing lynx » Thu Mar 24, 2016 10:29 pm
if you have a Charlies store near you they do a pack of roll pins for a couple of quid there should be one in there
Postby Adam_Winstone » Fri Mar 25, 2016 12:32 am
Adam
holty
:D
.... I'm looking for the LIKE button.
Postby Wack » Fri Mar 25, 2016 9:07 am
I do the same, tap rod to M5 and use a bolt but another tip with the roll pins is to put a lockwire through it.
Postby HxPaul » Fri Mar 25, 2016 9:58 am
I use a nut and bolt on the gearchange and the throttle rod,never come lose even after 6 years of use.
