Varitronic curve
Varitronic curve
Postby Raveydavey » Thu Mar 24, 2016 12:23 pm
I'm trying to work out what deg BTDC my Varitronic will be at when the engine is at 6000rpm when starting at 22deg @ fast idle. The strobe shows it going up to about 15deg BTDC at what sounds like high revs, but dont have a rev counter so its just guess work. Does anyone have details of the curve showing where it retards? I'm guessing it is at set steps?
cheers
Raveydavey
Re: Varitronic curve
Postby Digger » Thu Mar 24, 2016 12:32 pm
Digger
Postby Raveydavey » Thu Mar 24, 2016 12:59 pm
Thanks Digger. I do have that already,
In that curve it shows fast idle@ 23deg which it holds to 4k rpm. Between 5 and 6 k it drops steeply (four deg) from 22 to 18 and then trails off; 6 to 7k = 2 deg; and 15 deg comes in at 8000
So is it simply a case of shifting this curve down a degree to answer my question? i.e. starting @22deg (1 deg lower), at 6k I'd be @ 17deg. If it does then it should mean 15deg comes at 7000?
Raveydavey
Postby Digger » Thu Mar 24, 2016 1:19 pm
I'm sure a grown-up will be along in a minute to answer that one.
Digger
Postby Raveydavey » Thu Mar 24, 2016 1:46 pm
Digger wrote:I'm sure a grown-up will be along in a minute to answer that one.
:lol: :lol: :lol:
Raveydavey
Postby Sticky » Thu Mar 24, 2016 2:14 pm
Raveydavey wrote:Thanks Digger. I do have that already,
Essentially yes. The Varitronic uses the same basic stator as a the Casatronic. There is a diagram of the curves at various stator positions at 7:54 on this video I made for Casa Lambretta.
Sticky
Postby Raveydavey » Thu Mar 24, 2016 3:18 pm
Perfect. Cheers Sticky.
Great vid BTW. Im sure I had more fun and games than that when I fitted mine. :mrgreen:
Raveydavey
Users browsing this forum: Baidu [Spider] and 77 guests
