Filso Milano Flywheel
Postby Hammer » Tue Mar 15, 2016 8:58 pm
I'm restoring a 1962 LI 125 series 3 and nearly have the engine stripped. I'm just a bit confused about the flywheel. I bought a standard flywheel holding tool with 2 cutaways one side and 3 the other but it doesn't fit my flywheel. My flywheel has "Filso Milano" printed in the casting and is made of aluminium and the dust cover is the 2 screws type. The flywheel has 1 large window and two smaller ones. I wasn't aware that the series 3 used a different flywheel? Any light that can be shed gratefully received. Also I guessing that in order to hold the flywheel I will have to either source an non-standard holding tool or take it somewhere to be "shocked" off with an impact gun?
Many thanks in advance.
Hammer
Re: Filso Milano Flywheel
Postby ToBoldlyGo » Tue Mar 15, 2016 9:36 pm
I think the S3 used a variety of flywheels. You've probably got the most awkward. :lol: People must remove them though, so there has to be a way of doing it.
ToBoldlyGo
Postby rossclark » Tue Mar 15, 2016 9:43 pm
Ducati, Dansi and Filso all made flywheels / stators for the S2 / early S3.
Filso and Dansi are generally thought to be the best doorstops.
Postby Norfolk » Tue Mar 15, 2016 9:58 pm
Now this might sound a bit of a bodge but"................in the past I have wrapped a rope around the circumference of the flywheel and held / stood on the end to hold. Do not hook the rope onto one of the flywheel fins.
This method might raise some comments but all I can say is it was suggested to me several years ago and has worked without any problems.
Norfolk
Postby Hammer » Tue Mar 15, 2016 10:22 pm
Thanks, I was seriously considering keeping this on 6v points but am rethinking this now since Filso doesn't seem a great system. With a bit of grinding and hacksaw action I reckon I can adapt the holding tool that I have and get the flywheel off and then set up a decent 12v electronic kit.
Hammer
Postby rossclark » Wed Mar 16, 2016 2:01 am
I have seen it done with a rope where the rope was woven through all the fins.
Also with a knotted rope in the spark plug.
If you take the top end off you can use a conrod holding tool to stop the crank (or an extension bar through the small end and a couple of blocks of wood if you're stuck).
I also have a homemade tool that uses two bolts mounted on a solid bar that can be used with care on most flywheels.
Do remember it's a left had thread :-)
Users browsing this forum: Google [Bot] and 34 guests
