foremanbob wrote:i believe that there has been an issue with the positioning of the upper damper brackets
corrado wrote:Early GP ones had the groove for the headset bolt too low so you had to file it longer by about 3mm. It was easier to elongate the slot than it was to return them. I never bought any more but this issue was raised by Sticky in an article in Scootering Rag at the time so presumably they rectified the fault, though I can't confirm that.
