Engine advice....please
Postby Alex_amd2001 » Fri Jul 18, 2014 10:03 am
Hi Everybody,
I'm 95% finished my resto project (li150 series 2 winter model), but having issues with starting and idle especially with the airhose connected (does better open). Everything is standard except the new carb, dellorto PHBL 25. Can anybody offer some jetting recommendations etc. Many thanks! Alex
AQ266 atomiser
102 main jet
40 slide
60 Choke
200 Float Needle Valve
50 pilot
Alex_amd2001
Re: Engine advice....please
Postby Wack » Sun Jul 20, 2014 6:18 pm
The only advice I can give is remove the baffle in the airbox neck and the wall in the air scoop , presuming they have them? This will allow more air to the carb. Check choke plunger is lifting when turned on and a 50 idle jet may be too big.
Postby Alex_amd2001 » Sun Jul 20, 2014 8:44 pm
Thanks Wack,
I'm going to try a 45 idle and maybe a remote filter. Appreciate the advice.
Alex_amd2001
Postby GeneM » Mon Jul 21, 2014 4:52 pm
id drop to a 264 or even 262 atomizer
GeneM
Postby Wack » Mon Jul 21, 2014 5:42 pm
Agree re the atomiser but better to get the bike starting and idling first then work from there. :)
