Bloody awful job, when you haven't got a motorbike lift.
Storkfoot wrote:I don't mean this to sound off in anyway but may I suggest that you do some of your own research on these subjects - it can be dangerous to assume that all the advice you get on scooter forums is sound. The piston to bore tolerance on an iron barrel 2 stroke is important.
For what it's worth, I know someone who used one of those three pronged glazebuster tools in a hand held drill. Suffice to say, they then needed a rebore.
johnnyXS wrote:hows it going Chris ?
have you had any time to work on the scoots last week ?
Us armchair wrench jockeys need out weekly fix![]()
All I've managed to do is take my clubman back to bare metal witha flapwheel . Awesome bit of kit!
Storkfoot wrote:...........I know someone who used one of those three pronged glazebuster tools in a hand held drill. Suffice to say, they then needed a rebore.
I thought that type of honing/glaze busting tool was not for use in barrels with ports in, just 4 strokes.
Warkton Tornado No.1 wrote:
The type depicted is a Sykes Pickavant though you types that like a bit of 'bling', such as eight stud wheel rims & hubs, could spend a lot more on a Snap-on.
Warkton Tornado No.1 wrote:I thought that type of honing/glaze busting tool was not for use in barrels with ports in, just 4 strokes.
Honing is fine if you have the correct tools & attitude.
The longer legged honing sticks you can get, the better, & obviously plenty of lube/coolant. The ports will be alright as long as the sticks are not so short that they be allowed to spring into them.
Kristof Lammy pie wrote:I will see how I get on, the bore has some glazing but to be honest I'm not too worried. As the motor is being removed in few months anyway, I just want it up and running to get it registered
I've now got a spare lis125 motor that I can take apart rebuild and upgrade to a 186 or 200.
Users browsing this forum: Baidu [Spider] and 91 guests
