Wal Phillips Fuel Injector
Need help identifying that accessory? or just want to show off some of your Lambretta memorabilia? .......... This section of Anoraks Corner is for members to show off their Lambretta accessories and memorabilia.
Strict no chatter
Postby Dimitrios_231 » Fri Feb 12, 2016 10:11 pm
I just can't say no,
my latest,
it needs a really good cleaning.
Dimitrios_231
Re: Wal Phillips Fuel Injector
Postby Dimitrios_231 » Mon Mar 07, 2016 8:44 pm
Much better now.
Dimitrios_231
Postby coaster » Mon Mar 07, 2016 9:44 pm
Don't leave your fuel tap on or the inside of your engine will be as clan as the injector ;)
Postby Dimitrios_231 » Mon Mar 07, 2016 10:09 pm
Τhank you for the tip ;)
I have used in the past the Lambretta version of the injector,
it was shorter and could easily fit under the panel,
the problem was that it couldn't breathe so you still had to run without a panel or make a hole in it :)
this one was clamping on a standard 20 mm S3 manifold like a normal carb.
Dimitrios_231
Postby Scooter Paul » Tue Mar 08, 2016 9:57 am
I used to run one of these back in the sixties. In those innocent days we just bolted things on and they worked. I do remember having to run without the side panel, not for clearance issues but so I could put my hand over the intake to 'choke' it for starting.
Paul.
Scooter Paul
Return to Accessories and Memorabilia
Users browsing this forum: No registered users and 30 guests
