by rodders » Sun Feb 21, 2016 9:32 pm
My scooter seems to lose a lot of power on hills. Intact a slight incline slows it right down. I know that the exhaust needs to be replaced, but could that be the only problem or could it be something more serious. Would a service with new seals fix this problem?
rodders
by Marty ULC » Mon Feb 22, 2016 8:58 am
It could just be that it's a 125.
Marty ULC
by CHRIS in MARGATE » Mon Feb 22, 2016 9:13 am
Replacing the seals won't fix anything if they are not worn out. A worn drive side oil seal will produce plumes of embarrassing white smoke; you'll know if it's gone.
125 cc engine is far from powerful but I would replace the exhaust if you believe it to be necessary. Just fitting a Clubman style exhaust will give you a noticeable improvement but don't expect too much. Change the air filter at the same time and then the engine can breathe to its full potential. Worth fitting a new spark plug whilst you're at it.
by dave411 » Mon Feb 22, 2016 9:17 am
The 125 is dangerously slow on hills or inclines.
dave411
by rodders » Mon Feb 22, 2016 10:51 am
Cheers gents, much appreciated. I'll try that and hopefully it makes an improvement. Looks like I just need a proper licence and upgrade my scooter .
rodders
by johnnyXS » Mon Feb 22, 2016 10:56 am
assuming that your crankcase has the correct gear set fitted for a 125 I would check that your timing is not too far retarded ,thats the likely suspect . I set mine at 19 deg currently . Check the points gap carefully (if you have them fitted )and then look at your fuel mixture at the middle to top rev band.(check spark plug ) Check your fuel flow rate from the tank, check throttle slide opening fully at full throttle and your air hose is not collapsing when you open the throttle up wide ...... all the usual stuff
if that is all spot on I would do a compression test .
johnnyXS
Users browsing this forum: Google [Bot] and 30 guests
