Sticky wrote:
Revealed exclusively a week or so ago.
Based on an Innocenti mould, internally strengthened and with a dedicated 8-point-fixing tubeless alloy wheel rim to match. More info to follow on SLUK.
Marty ULC wrote:Surely a rim that fits the rear hub will also fit a standard front hub assuming the studs are compatible. There'd just be 4 unused holes.
coaster wrote:Being a tubeless rim, why carry a spare rim? just carry a tubeless puncture repair kit and some gas canister inflators. You don't see any motorbikes or modern scooters carrying spares
HxPaul wrote:Marty ULC wrote:Surely a rim that fits the rear hub will also fit a standard front hub assuming the studs are compatible. There'd just be 4 unused holes.
A standard wheel would already have four studs inserted which will prevent it from fitting on the rear hub.The only way that an eight stud wheel would fit is to use tubeless rims and you would have to drill the four extra holes or remove the studs in the hub.
rossclark wrote:Anyone with a drill could make the wheel to fit.
I used to have an RB 25 engine and one of the reasons I got rid of it was the torque shredded two good hubs (one Spanish) when I was giving it the beans and that had nowhere near the power the BCG has.
Users browsing this forum: Google [Bot] and 35 guests
